Custom/Hybrid Extension wire
jps
FRANCE 64
hello, i need to know if The superjet extansion wire on The ebox 6R7-82553-01-00 existe on more longer.
I need to build a rickter fr2 and the wire is too short.
If you have a model in another ski is longer than The superjet and plug and play.
Thank you
eastcoastjumper
James
Long Island
Thank you
Hot products sells the oem plug ends. You can build a longer harness if needed
Yes, you can build your own harness out of Sumitumo plugs and motorcycle connectors. Or you can order a B1 Blaster harness which is pictured. Or I could mail you one, shortened with the proper connectors , made to your specified length.P1050419.JPG P1050420.JPG
I just priced a new one from Yamaha- it's a hundred dollars more than the normal Superjet harness.
62E-82553-00-00 EXTENSION, WIRE LEAD 1 $ 147.99 (retail) , forget that!
It is not difficult to take a used one (plentiful in US) and shorten it for you with the proper connectors.
Several members here could do that, even make a new one (I would have to order more Sumitumo
plugs first- the black and white ones)
