Vumad
Super Hero, with a cape!
- St. Pete, FL
ya I am super pumped on my motor setup I think this ski will rip! I work at my parents car stereo shop so I have made a bunch of custom fiberglass boxes (have 6 eights in my double cab tacome, yes i still have all my seats). So I have a pretty solid idea on how to glass, I just haven't used cloth before as all of our boxes are made from chop strand mat and poly resin.
the info I'm chasing after is what cloth I should be using. I know everyone uses 1208 and 1708 but is there anything better. thoughts on s-2 glass as well specifics would be awesome.
I am ready for layup on the top of the ski (hood and top of nose). I want to get that all done and reinforced first so I can look up through the gapping hole on the bottom of the hull to make sure that the hood is sealing properly. then I will proceed to other parts of the ski @vamad
I have only received one answer on the intended reason this thread was started, from schicks! Again I am looking for answers on what kind of cloth I should be using.
If you are doing the hull and hood, cover the foam with plastic or packing tape first. This will keep the resin out of the foam, making it easier to remove the foam, prep the new layup and to do the second layup on the inside easier.
It doesnt matter if you use 1208 or 1708. They are both the same except for weight. They are both a weave sewn to a chop. The areas you are working are flat and will layup easy. The major difference between the 1208 and the 1708 is how fast they bulk. The 1208 takes more labor to lay the same thickness as the 1708. The part you are working is flat, so 1708 is fine. 1208 will be easier to work on theharder conyours of the bottom.
On the top deck and hood, i would sand the foam down about 1/32" from flush, then cover it with some plastic. Actually, i prefer to use drywall mud and packing tape on the foam and waxing the tape so the new material doesnt stick. Prep the hull so the new material does stick.
i would layup a layer of 1208 only over the foam pretty side down, then a second layer about 1-2" overlap of the original hull pretty side up, then a 3rd layer of 4oz conform cloth about 2-3" overlap.
When its all hard, i would then go inside the hull, removing all of the foam, mud and plastic / tape. I woukd then prep the new layup on the original hull. Next i would layup 1708 to fill the void created by the thickness of the original hull unyil its all pretty flush, you can use also heavier weaves like 24oz cloth too to bulk faster for this part. Then, once its bulked up and flush to the hull, i would layup 3 layers of 1208 at 1, 2 and 3" overlap finishing with a 4th layer of 4oz conform cloth 4"overlap.
Then fair in the inside and outside with epoxy mixed with talc.
You may be able to use a layer less, but youve eliminated the entire structure of the boat, so id go heavy or budget to do it again.
The nose and tray can be done the same way, but the tray all has to be done from the outside. Thats okay though, because the turf covers the changes in the body shape.
I would encourage you to evaluate your cooling and control tubes while you have the back open, and consider drains and rear exhaust.
The glassing methods i suggested above are prequals to my "on the part" methods when you are ready yo waste a few bucks on molds or bagging.
