I picked up a 98 SXi Pro with a Factory Dry Pie and a EWCI (water injection)...I had to take the head and exhaust and clean out oll the cooling ports, blew air through all the hull fittings to make sure they were clear. The issue is when I had it on the water, the water box got SUPER hot, water on it boiling hot. Any ideas what would cause this?
The switch setting are verifed correct on the control box for a stock motor...
