BruceSki
Formerly Motoman25
- Long Island
all of the aftermarket manifolds are without a crossover
If you read what GroupK, etc say about filling crossover, they are only worried about deteriorating WOT signal. A crossover on a twin cylinder is in place of a boostbottle on a single cylinder. It cleans up low speed carburetion, delivering more power on the low-end, same reason some like to run a single carb on a twin.John at JSS holds the opinion that filling in the crossover reduces bottom end hit. He states he has done testing on the same ski by switching manifolds,one filled crossover and the other stock. He has found that the crossover helps low speed carb signal greatly and bottom end hit...This is contrary to opinion held by many threads on here, anyone believe this ?
That begs the question if he rejetted/tuned the carbs when he switched back and forth.
I did some testing on this yesterday. I made custom crossover on my SXR 800 engine with 48mm annular discharge carbs, made a big difference on acceleration, (and yes my carbs were jetted correctly before I did this)
Got the slight whiplash today to prove it
So are you saying your ski had better bottom end by adding a crossover ?
Yes, much better
If you read the research done by companies/engineers, they all say it gives cleaner/better response which is what we are after. A GroupK article refers to the downside of deteriorating signal at prolonged WOT, something that won't affect a freestyle machine. All the AM manifolds were originally made for racing
Eric Malone keeps the cross-over setup on the backflipping Q8 with SXR motor, I think he knows more than most of us
Yes, much better
When you say you added a "cross-over" what exactly did you add? Is it an external piece, ie one boost bottle connected to both intake ports?
Connecting the two cylinders will make the power delivery smoother, and you lose the capabilities to individually tune each cylinder. This works best on a "single carb application" This is what I found with testing, so its based on my opinion only.
Regards,
Randy
