I have stock carbs jetted to Factory Wet Pipe recommended jets. See below for all mods.
Pop Off Spring = stock
Pop Off Valve = stock
Pilot Jet = 80
Main Jet = 152.5
High Speed Screw = 1/2 out
Mid and top end are crisp, plug is light brown/tan when run wfo.
When riding around at low to mid speeds the plug comes out wet and black. I'm running a quality syn. oil @ 60:1
If I turn low speed screw : [1 turn out recommended]
@ 1/4 out it idles better and smokes less with the plug staying much drier. Throttle is better from idle => full, but not as snappy I'd like.
@ 1 turn out I need to increas idle speed to make it run but the 1/4 => full throttle is better.
Actually I can turn the low speed screw to ZERO out and it idle good.
I was thinking a stiffer pop off spring and maybe a bigger pilot jet to compensate for 1/4 throttle response.
Pilot Jet = 80
Main Jet = 152.5
