- Ontario, Canada
Awesome! What setup do you have?
Believe he has SXR set up, Not sure on pump though.
Its a sxr in a Q8 185psi compression and wet pipe, pump is 145mm mag with skat 9-16 prop and trim.... Carbon hull weighing 83lbs and thats all folks
i was doing the same thing landing on my head for days,... you need to stand up and pull the bars toward you after your half way around, gets the ski to come around quicker.Awesome! Glad to see other people getting it done on minimal setups. Yours is a very similar setup to mine Same pump and prop, Im running 781 JetManiac motor and havent rode one out yet (check my youtube link in sig).
you'll get it!
Im 6'3" 230lbs and my pole lenght is 35" from pivot to bars
