$325 minus the cost to have a non Nikasil cylinder honed or bored when it's time to rebuild ( if Nikasil is very slow to wear).
I might be mistaken, but if it needs to be re-coated, then the old coating must be removed first. Is that included in the $325?
Zach, you mention that your CR500 engines with nic'd sleeves run cooler. I was always under the impression that the reason Nikasil heat transfer works so well is because it doesn't have to deal with a sleeve to begin with. So are you improving heat transfer of a steel sleeve by putting a layer of Nikasil on it?
Thanks for the info.
