Midlake Crisis
- Bakersfield, CA
I assume you mean the USB accessory cable, not the one affixed to the ECU?I had a bad cable once....same issues.
The friend I borrowed the cable from had some trouble with drivers but ultimately was able to connect and set his curve. It was new from ATP at the time, I am the second to use it and it still looks perfect so I am assuming there is something wrong with the ECU or female connector. IDK
