Freestyle Flame TL no spark
The only time I've had this problem is when one of the wires broke from the stator (pick-up) to the ebox. Took a while to figure out because the wires were not exposed, they were covered / wrapped inside an exterior coating.
Good luck, im sure you've checked all connections. Keep looking! :)
I had that problem last year. Turned out at the soldered connections from the pickup (behind the flywheel) was coming apart.
Just fitted my stock set up back on and fired right up
I was turning the fly wheel and the light wasn't coming on so I think it's the pick up its a version 1 and I think it's common for them to die so I just need to get a new pick up ?
