The only time I've had this problem is when one of the wires broke from the stator (pick-up) to the ebox. Took a while to figure out because the wires were not exposed, they were covered / wrapped inside an exterior coating.
Good luck, im sure you've checked all connections. Keep looking!
Just fitted my stock set up back on and fired right up
I was turning the fly wheel and the light wasn't coming on so I think it's the pick up its a version 1 and I think it's common for them to die so I just need to get a new pick up ?
