- Vegas
has anyone gotten the flat water nose stab down on a blaster? i get the nose in but not far enough i'm working on it... Vidoes? Pictures?
A lot easier on a standup, try a roll instead
yes i do, i need straps or build my idea for footholds.. i tuck my feet under the grab handles
You need to make a setup wake, as fat as possible, and then it comes down to HP and throwing your ski as hard as possible. It actually teaches you the body movement, so when you hit the surf you have far more control over it.
Approach the setup wave at a 45 degree angle, If you turn slightly the opposite way, then snap back the way you want to go as fast as you can, under full thrust, she should go around.
if you hace straps, lift, the rear up. OH and also almost tilt the ski 90 degrees side ways.
if that makes any sense,
I rode a carbon blaster with a DASA 1100 in it and it did nose stabs of nothing. crazy ski.
