Other flow control options??
Jetpilot106
Kickin it old skool
Ok the deal is I got a 550 with dual cooling.I don't think I'm getting enough water in my exhaust .I've been looking at flow controls like jet works and blowsion but I can't justifi paying 100 for 2.so are their any other options on the cost effective side that works as a flow control?
Dmac80sc
Here
What makes you think your not getting enough water? The flow control valves won't give you more water we run them to reduce the amount of water going into the water box to keep throttle response up.
Jetpilot106
Kickin it old skool
well first it was melting exhaust couplers.so I put a restricter in it to see if that would help.but now I don't have a whole lot of throttle response or hole shot anymore?
tor*p*do
Squarenose FTW
NW NC
if you are melting couplers and losing throttle
you are overheating due to LACK of water
Take out the restrictor and blow lines back to the pump
you probably have a blockage
flow control options.haha. what a funny title. i was thiinking maxipad with wings. but seriously. try getting a brass plug the same inside diameter of the water hose thats hooked to the pisser. then just drill a little hole in the midle of the plug to control water flow. basicaly just a restrictor.
