Dustin Mustangs
uʍop ǝpıs dn
- Holland, MI
I guess this is a multi-part question. First, do these two parts do the same thing? From what I understand they both regulate water going into the exhaust in relation to engine speed. The difference being that the valve does this indirectly by way of pressure in the cooling system and the injection kit works directly off of engine rpm. Is this correct??
Secondly, given they do perform the same function, which does a better job? The valve is much simpler (good from a k.i.s.s. standpoint) and also much more affordable. I guess the injection kits can have multiple injection points but couldn't you just use multiple control valves and get the same effect?? Given what a flow control valve does, I am surprised anyone even buys the injection kits with how pricey and complicated they are. I must be missing something here...
Lastly, is either a worthy mod for a stock boat? How about a mild limited??
I'm interested to hear what you guys have to say about these questions or any other thoughts you may have on the subject.
:Thinkingof_:
TIA
Examples:
Flow Control Valve:
http://www.jetworks.net/fc123.htm
Water Injection Kit:
http://www.jetworks.net/wik123.htm
EDIT: I just noticed the flow control valve page I posted claims it is compatible with water injection kits. If I wasn't confused before I am now...
:Thinkingof_:
TIA
Examples:
Flow Control Valve:
