heres the kicker,the ecwi works really good at getting better bottom end,but the solenoid is unreliable and would be even better at lower rpm ranges,the bpipe does ok at injecting water but no where near as good as a real spray bar at the right spot. was talking with a techy buddy about building this instead..But what really needs to happen for freeride power is the type of valve we are working on,that basically is a mechanical flow control valve working in reverse that cuts water off at certain pressure,rather than let it though at a certain pressure....the pressure will be relative to as low as rpm as desired.though the right spray bar this gives sick low end and still lets the ski rip through the midrange.best of both bottom and mid with out the worry of a solenoid craping out on you.He has built a prototype that is working well,should have something out soon.
