flywheel remove??
simofx-1
freeride
new zealand
about to have ago removing my 701 flywheel, and im not shaw if the center bolt is lefty threed(lefty loosey)? itried both ways with a spanner and it wont turn... i want to replace the bendix.
also is it just that centre bolt holding it on cheers
IS0LD0UT
I hate winter
MN
Standard threads. Left to loosen. Its the bolt and then friction with the crank. You will need a flywheel puller. I suggest the harbor freight one.
Iowa
Flywheel bolt is standard thread and is only thing holding flywheel on
fwiw get a flywheel lock and a harmonic balancer puller but be careful not to damage stator by threading puller bolts too far into flywheel
I used an air impact and a flywheel puller and it came off with ease. Just had to do this myself a few weeks ago
Sent from my SM-N900T using Tapatalk
The fly wheel puller should attach to the face of the flywheel by 3 bolts. You should see 3 holes around your flywheel bolt. Then there should be a bigger bolt with the puller that goes in the center. That's what you hit with the impact.
Buy a good puller, i made a puller but almost ff'ed up my crank :p I bougt a puller for kawi / sj. Good solid steel one, it popped right off..
Greetings,
