Mark Gomez
is where the surf is
- Fullerton, CA
Surf riding in Oceanside today, I went to slash a building face which walled up very quickly sending my nose down and under hitting the ocean floor. It wasn't too bad I was still standing in my ski waiting to float up or have the nose angle up so I could hopefully ride out of it but the nose was stuck, Idk how but I was under a second or two longer than I should have. The ski was still Idling the whole time until it reached the surface when I felt a (Dunk) and the motor stopped.
I understand she took a gulp and swam my ski to shore to pull the plugs and try to get the water out. When I hit the start button the ski hardly turned as if my battery was dead. I instantly assumed my bad starter just called it quits and got towed back in.
So hours later with water in my motor still and installing a good used starter The same thing happens leading to take apart my top end revealing... THIS!!(attached photos)
My 3 month old hot rods crank and 1 yr 2008 OEM pistons. DONE
Surf Slam T minus 2 weeks and need a full motor overhaul plus practice
FML
:banghead::banghead::banghead::lightning:Attachments
