- Home of the Steelers!
I've been swamped with work and building a new garage and just life in general, but I actually spent a little bit of time getting ready to start work on my FootRocket. Used a tap and cleaned some of the epoxy/glass out of the inserts inside the hull so bolts can now be easily hand threaded. Fooled around with with footholds, which needed a little work to get them to bolt properly to the adjustable brackets. Then took a look at the scupper valve which is not installed. I believe it's a WORX scupper. I looked for threads addressing installation methods, but couldn't find anything.
I suspect I'll put some 3M 5200 around the scupper and drill it and just go with that for the install, unless anyone has any recommendations. BTW, what's everyone's thoughts on flapper straight down versus angled towards the back of the hull??
