For every one who can't afford B-pipes whats the next best thing?
I don't think so. Perhaps dry it out a bit. IMHO, the stocker is a turd not worth anyone's time.
Speedwerx is awesome, both versions.
Mike W
Infidel
North Florida
Palmer said:
Can anything be done to the stock pipe to improve its performance (even if only slightly)
The only thing you can do with is to remove it. I have a Riva pipe I will be removing from my square next week if your interested. Its a good alternative to a B pipe. PM me if your interested.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
accbr said:
I called Coffman to get the jetting for a 701 for a sizzler pipe, and she told me they never made a sizzler pipe for a 701???? I have one on my 650 that I was gonna use.
IM using that coffman sizzler on my 701, I got jetting specs from Magoo ( its really close to factory B pipe specs I think) I have ridden it a few times, but I think ive got an air leak so I cant really comment on the power its making. other than to say its stronger than the 650 that was in there with the same pipe.
I had to open up the exhuast manifold to match the larger ports, thats all.
accbr
addicted
Lexington, KY
Could you send me the jetting you're using :Banane01:
I'm gonna match the exhaust ports up too.
oxnard111
Creative RE Purchasing
hangtime said:
Ya a new one for about $650 with all required hardware and new everything or a used one needing gaskets and maybe coupler or clamps and perhaps a frozen screw for $500 :rolleyes:
Where is this place you speak of that sells them for $650? The cheapest I have found for a brand new one with the Limited chamber was $700.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
120 pilot, 145 main
1.5 n/s
95 gram spring ( I think)
the coffman pipe came with the 650 engine I bought, and I ran it for a LONG time and it ran good with 120 P, 138 Main jets in the carb for whatever that is worth.
