Fouling Plugs?
stupidgoodness3
X-H2Dizzle
ok heres what going on.. I have a 95 Sj it has a b pipe, 46mm carb, stock bore, milled head 170 compression, skat impeller pitch unknown..
About two weeks ago it fouled my back plug ( cylinder 2), ok no problem I just bought it a couple months ago and who knows how long the plugs were in. Now today I took it out and the back plug once again as fouled.. What could be causing this to happen?
I have been mixing it at 50:1 with yamalube...
-jay
crammit442
makin' legs
here
-jay
If it runs well with new plugs, change your plugs more frequently. Many people run the same plugs far too long. They're cheap.:biggthumpup: Change them often. Don't waste your money on expensive iridium or other fancy plugs. Just use standard NGK. I change every 3-5 tanks of fuel.
Charles
stupidgoodness3
X-H2Dizzle
Charles
yah but after only 2 weeks on brand new plugs? and I only go out once a week..
jetskiking
Im done sanding!!!
Dallas Georgia
Charles
Dont you pull that motor down every 3-5 tanks also? J/K:biggthumpup: . Charles has probably the best mantained boat out there and it shows by how it runs. I do find it odd that you are only fouling one cylinder. The coil fires both cylinders at the same time so that is somewhat ruled out. Its a single carb so that somewhat rules out jetting. Is there a big difference in how the front and back plugs look when you pull them?
crammit442
makin' legs
here
:booty: :booty: :booty: :booty: :booty: :biggthumpup:
stupidgoodness3
X-H2Dizzle
they look pretty much the same with a nice color on each one but for some reason only the back one is fouling.. probably 1-2 tanks of 50:1 yamalube went into these brand new plug..
stupidgoodness3
X-H2Dizzle
yah, and now the back plug boot does not seem to be snaping down on it like on the front. So im hoping this is somehow the problem..
