Frankenstein/Superbeast
Kaveman
Born in USA(not Kenya)
HULL
XFT surf version 79 lbs.
JPEngineering fuel filler
rear of bond rail below tray cut out for trim
dual one-way XFT scupper valves that empty onto ride plate
Hydroturf with the same on the bond rail
XMW dual breather pivot and bolts
XMW -2 pole
X-scream chinpad
JPEngineering hood hooks
DRIVELINE
148mm Skat Trak magnum with 2 extra props
Sato Engineering trim system reduction nozzle bored to 85
Fischer dual intake grate
XFT ride plate with "D" cut
UMI "Kawi" couplers
STEERING
UMI steering system
X-metal shortened turn plate with straight bars
ODI ruffian grips with thug plugs
steering pivot moved all the way in towards steering nozzle
UMI clear billet aluminum throttle; straight pull
ENGINE
74mm x 85mm 840cc
LPW ported Lamey power valve cylinder
Precision Powersports epoxied and ported 62t cases with crank relief by LPW
Protec billet 74mm crankshaft (+6mm) with stock length rods
R&D Dominator flat top pistons 85mm modified by Precision Powersports
ADA girdled cylinder head with 26cc domes
Boyesen dual 48mm intake manifold with R131A rad valves
Full Spectrum dual 48mm carbureters
Mikuni dual feed remote fuel pump
Fly flame arrestors with outerwears
Factory Pipe b with mod chamber, head pipe and manifold modified by LPW, chamber from 2003 Polaris Octane.
Jet Works flow control valve
dual 90 degree water bypass fittings
ELECTRICS
Oddysey battery
MSD Pro Digital total loss system dual pickup and dual coil mounted to Precision Powersports aluminum lplate
NGK BPR8ES spark plugs
oem starter, switch and relay
OVERVIEW
That's pretty much it...Just purchased project XFT hull, but it's rideable til winter! The last pieces are hood and nose piece. Still trying to decide, but I don't like Sergios' "boobs"!
RoyalFlush@PCB
Shootin' The Crap
PCB
Fly by night? Possibly! Actually we fly every chance we get. How do I upload pics to this site and attach them to a post?
When you reply, click on "Manage Attachements" and then "Browse" to find your pictures, then click "Upload".
How's it going, Kevin?!? :woot:
Kaveman
The revamped Superbeast
Just updated the Superbeast.
HULL
XFT surf version 89 lbs.
dual one-way sump pump valves that empty onto ride plate
Jet Traction with the same on the bond rail
XMW -2 pole
E_rok_wilbs chinpad
DRIVELINE
Stock jet pump and wear ring
TBM pump stuffer with meduim cone installed
Solas 13-16 concorde cutback 3mm by Impros
UMI "Kawi" couplers
STEERING
UMI steering system
ENGINE
74mm x 85mm 840cc
ELECTRICS
Oddysey battery
OVERVIEW
Kaveman
Where The F Are The Pictures?!? :drillsergeant: :pokey:
Sorry sarg, I have tried to attach them to a post, but they are too large. When I tried to upload to my gallery, I get a message saying "0 uploads were successful". The pics I have are between 1 and 3 mb. Is this why I am having isues? I'm a bit electronic iliterate, still taking classes on how to use a rotary telephone...these things are awesome!
Kaveman
Been brainstormin. My camera is an 8.0 mega-pixel. The pictures are 3200 x 2400. The file size limit says 1200 x 800. I set my camera to 1.1 mp, this shrunk the files to 1200 x 900. Hopfully these will be small enough as the attachment manager states that it will resize if possible. I will take some more pics soon and try to upload again.:fingersx:
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Wow, sounds like an amazing ski. Let me jump on the 'wants to see pics' bandwagon!
Here is a nice little photo resizer if you can't get your camera to do the dirty work for you. Give her a click and save it some where convenient. The 1500 in the file name is what it will resize them to. You can change that number in the filename to whatever width you want. Then drag and drop an image, a selection of images, or even an entire folder of them on this icon and it will resize them to whatever size you specify in the file name (again, 1500 as downloaded). Re-sized photos will show up right next to the originals once it is done. Hope this helps!
:beerchug:
http://www.msu.edu/~remondi2/other/PhotoResize1500.exe
Waste Land
Non Multa Sed Multum
Florence, AL
Any ANY size pics to me at BrokenSJ&Gmail.com and I'll rezie, host and upload for you
