Super Jet FREE, TRIM CABLE THRU HULL SEAL
yamabro
GP Performance / Patterson Powersports
Dickson, Tn.
Utilizing a part that we all throw away or have several just laying around.
The OEM Yamaha overheat, temp sensor.
You will need:
  1. Yamaha OEM temp sensor. (removed from the E-box)
  2. Straight pick or small flat tip screw driver
  3. Wire cutters
  1. Take your straight pick or flat tip screw driver and wedge it between the metal base of the temp sensor and the rubber grommet.
  2. Pull on the metal temp sensor while holding the rubber grommet to expose the wires and slide the rubber grommet out of the way.image.jpg
  1. Cut the Pink And Black wires close to the base of the metal temp sensor.
Install your new "Free" THRU HULL SEAL.
You can use zip ties or SS hose clamps to mount securely.
WHAT TO DO WITH THE LEFT OVER WIRING HARNESS
http://x-h2o.com/index.php?threads/...ss-bilge-pump-power-supply-conversion.168013/
Great idea. Just made three of them. Guess I need to buy some more hulls now :-/
