I have some questions about the rules regarding hull dimensions.
I understand the minimum length and width requirements. About the height requirement, I'm assuming that is including the hood?
What is meant when they state "The hull may be no smaller than the minimum measurements of the top deck"? I see many aftermarket hulls with top decks that extend far past the end of the bottom deck.
They state "the length of the top deck must be no less than 165.1 mm (6.5 inches) shorter than the original OEM top deck" given a superjet is 88.2 inches and they state a minimum length of 76 inches does this then mean that a hull must be between 76" and 81.7"?
The rules seem to imply that aftermarket hulls are based off an OEM hull. What about a hull made from the ground up? Is that even legal under these rules?
I am also unclear of what the regulations are on bond rail dimensions if there are any.
Link to rulebook: http://www.ijsba.com/pdfs/rulebook/rulebook_2014_all.pdfFreestyle ONLY: The top deck of freestyle craft may be modified or aftermarket, providing the following: The
top deck must resemble the original top deck of the homologated watercraft; the length of the top deck must be no less than 165.1 mm (6.5 inches) shorter than the original OEM top deck and the width of top deck must be within 50.8 mm (2.0 in) of the original component; the craft must function as originally intended. The hull may be no smaller than the minimum measurements of the top deck. These restrictions also apply to the minimum length of the hull. The front bumper may add no more than 31.75 mm (1.25 in) to the overall length of the Top Deck for the purposes of meeting the minimum measurements. Fuel fillers may be relocated internally.
Freestyle, Ski Type, ONLY: The top deck of freestyle craft may be modified or aftermarket, providing the following: The top deck must resemble the generic look of existing homologated watercraft with the following dimensions: Minimum Length of 193 cm (76 in), Minimum Width of 68.5 cm (27 in), Minimum Height of 53.3 cm (21 in).
