you are correct, I hadn’t even thought about that.
I am not sure, I would assume what was in the filters was the epoxy since it was only an issue on that carb but there was some small bits in the other one as well. The stuff was a slightly different shade than what was on the carb but I figured fuel exposure discolored it. I could be totally wrong and it may have gotten by the filter if the paper side separated from the housing. Regardless I’ve changed to a different style filter now.
As far as it breaking down I’m assuming the fuel seeped in from the underside of the plug and ate away at it from the bottom up? Maybe Ed used a different style of expoxy there assuming it wouldn’t see fuel? If you look at the images again you can see where there was some sort of goop under the plastic pump disks that I had written off as dissolved epoxy but that wouldn’t make much sense would it?
