Blaster Fuel/Oil Leaking from Spark Plug
westjon86
Blast eet!
Philly
I recently installed a brand new ADA head on my ported 64X. After riding it during break in I noticed fuel/oil puddling around the spark plugs. No bad symtoms. Ski actually ran great. I removed the head and double checked all o rings and everything looked good. I am using NBK B8ES spark plugs. Appears like it is moving up the threads of the plug. Any idea on what else could be causing that or how to stop it?
First check to make sure you have all the orings installed and two the check tightened spec. Are you seeing any water in the cylinders???
westjon86
Blast eet!
Philly
I guess the plugs do seem a little loose when im threading them in. No water in the cylinders. I'm taking it out tomorrow so well see what happens with a new set. I put in several sets on the first ride to check the jetting. Maybe I got a bad batch, all from pep boys.
