Super Jet fuel problems ?
hey guys im rebuilding my 96 superjet and when i put the new fuel lines in it wont start but unless i pump the primer only runs for like 1 or 2 seconds then cuts out i got clear lines so i can see were the fuel is it looks like it isnt even pumping threw there is air in the lines from what i can see any suggestions ??
cheers Rory
Byeai
"Cheetos-Man"
Melbourne FL
Put ur hand over carb and crank the motor should see fuel go threw the line till it hits the card or if u have choke put that on but u said primer so u have to choke it to get vacum going
Sent from my SAMSUNG-SGH-I897 using Tapatalk
JetManiac
Stoked
orlando
Are you sure you have the lines hooked up correctly?
Fuel from tank to bottom fittings on carbs and return to tank on the top fittings. Also pulse (fuel pump) fittings connected properly to cases? Make sure these lines are tight.
I like to crank a fresh build with stop button also pressed to allow the fuel to begin flowing before firing the motor. Then let sit for a minute. Then start it.
