- Lewes de
I'm building an alum. Jet boat using a super jet 701 as my power plant. I put the fuel tank (8 gal) in the back 1.5 feet behind but level with the motor. The problem is when I floor it from a stop, after three seconds it dies? So I hooked up a 1 gal tank in front and above the motor and it ran awesome. Also I took the return line out of the 1 gal tank and saw there was no gas flowing back in? Does the fuel pump that runs off the crank pressure have enough power to push the fuel or do I have a problem the fuel pump itself? Any comments are appreciated thanks
