surferdude345
X-H
- Blacksburg for school
Im thinking about just getting rid of the fuel switch on the sj, i really cant see the point i would rather have put the bildge there. Can i just get rid of it and cap off the res fitting on the tank?
LBE said:Why the F*** would you get rid of your reserve??? Sorry guys, but I think this a stupid idea. I know lots of guys have done it but I can't understand why. I see racers running dual carbs, that use the res to feed the other carb so the rear carb does not run lean, but otherwise I don't see the bennifit.
Just drill another hole if you want to run the bilge. When you run out of gas you'll be thinking "Why the F did I get rid of the res?" And no one say anthing about weight cause a 2oz switch aint conna change a thing.
Sorry for the rant, but I think is a dumb idea. :rant: Seriously, if there is some bennifit, someone clue me in.
I know the bilge fittings shoot out of the tray at 45deg, but when they slow down some will get in the tray, along with gas and oil thats in the bottom of the ski, and then you have a slippery mat.
Just my opinion.
surferdude345 said:Im never far from gas nor have i ever run out so i have never had to use the reserve so i cant see the point its just taking up space.
LBE said:A 1 1/2 in by 1 1/2 in piece is taking up space? Just my opinion, as stated. If you don't think you need it then take it out.
I don't usually need my helmet, but that one time that I do, Ill be glad I'm wearing it.
This is just something to keep in mind:
Just my opinion.
jetskier79 said:And a quick disconnect would mean you'd be required to remove your hood to make the change.
michael950 said:I intentionally ran the thing dry because I was changing premix oils. .
