FX-1 FX-1 Pictures Vids & Parts list.
Reviving this thread from it's watery grave.
Lets see some more fx-1 love people.
WSM Platinums, 710cc bore, Sizzler exhaust, protec head, lightweight flywheel, JD intake and plate, skat prop sitting on my bench waiting for an impeller tool, lol.
swapmeet
Brotastic
Arlington TX
I agree, here are a few i've owned, starting with my latest project. "Tenacious Ski"
The engine that was in this, is now in the ski above, and this hull belongs to Dragginblazer
And this is Fat Jesus, my first FX1
uk
heres my recent re-build, still not totally finished...
hull:
aluminium pole
sponsons
holds
ride plate
intake grate
driveline:
ADA head
carbon reeds
wetjet intake
48mm ATP carb
aluminium charging flywheel
true fx-1 B-pipe
flow control
kawi 140mm pump conversion
R&D big hub pump cone
hydrospace impeller
to do:
fix timing and set up carb
buy A/M CDI.
get it turfed
will try get an assembled pic up...
My fx1 project, i bought it last winter.
To do/doing:
Footholds
Refoam
144 conversion/hooker
paint/turf
Kart tank for now
Rebuild Motor:
701 61x 1mm over
48mm Riva Powerbomb
Factory Bpipe Limited
ADA Girdled Head 35cc Domes
Lightened Flywheel
uk
To do/doing:
Footholds
Refoam
paint/turf
Kart tank for now
Rebuild Motor:
701 61x 1mm over
48mm Riva Powerbomb
Lightened Flywheel
View attachment 152412View attachment 152411View attachment 152410View attachment 152416
I would experiment/research the carb thing before sinking cash into a 48mm. i have 48mm carb here with the atomiser thing removed and its a nightmare to tune. i am goin back to a 44mm for now, see if that helps....
p.s. looks good...
p.s. looks good...
I have almost the exact setup but ported by DASA cyl. That carb once dialed in has been awesome, just remember it needs a 165/170 restrictor in the return line, otherwise it will be a pain and never run right!
uk
yeh i have the restrictor, i personally think i may be having other issues which is making it worse, but there doesn't seem to be a 'somewhere near' setting with this carb its either bang on or miles out either way! i am going to start changing a lot of other parts too as i think i may have a temprimental stator
Here's my 94 FX1, I bought it from the original owner in 97. Has been garage kept it's entire life. I have had some issues with it recently but i finally got them worked out and it's now kickin butt. And i'm Back to enjoying it again. I ran across this forum a few months back so I am fairly new here.
Factory B pipe
Triton head
solas 19-25
R&D toploader
DG aquavien
Umi steering
Boysen reeds
SBT trued and welded crank.
