Freestyle Fx1 vs rn vs sn
chriselmore_1
high on resin
san jose ca
The 2 that I did on my old sn took 5-10 mins. And I never had an issue with the hood hooks... I also dod about 5 mins worth of grinding on mu old RN AC pole.
Don't forget to add in the hours spent grinding down the nose of the pole and grinding the stock SN bracket to make the pole rotate far enough in the upwards direction. Oh and also add in the time to figure out how to make your hood hooks work with the new setup.I have made RN poles work with a (modified) SN pole bracket and after doing that I will gladly throw down $150 for a Hazzard bracket.
michigan
Yea I wana make sure i do it right this time I'm thinking about a sn with a 62 t I'd rather have the option of mixing it more I know I'm gonna wanna keep going bigger haha thanks man what's the difference on prop pitches I'f u don't mind me asking
I picked up an old (clean) square hull off a buddy for $200. Got a good condition and complete 701 (61x) out of a blaster from that other forum for $450.
Soo in the end I have a clean square with a 701 for a total investment of $650. Can't beat that.
michigan
Can a 61x electrical work on a 62t motor or would it mess somthing up? And how much dose a 62 t normally cost I'f it is stock. And heck yea man u cant beat that did the haul come with most the ineareds ?
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Yes, 6M6 and 61X electronics are interchangeable with each other, but the 62T system/parts will not mix with with the 6m6/61X stuff. You have to use one or the other in order for it to work "correctly".
