grezzmky
Suckin paint fumes
- Saint Louis MO
No welding, just taking out a bit more material from cylinder and sleeves.
I can tell you that going from the enhancer + 165psi to TL and 200 psi was a big difference.
Putting in the mag pump after that was a HUGE difference.
THAT is what Im saying! you spend $2500 to get this engine built AND STILL ended up with mag pump, higher compression and TL.... How muche difference would there be between a ported 760 couch motor with TL and a mag pump. I understand that the couch motor looses some bottom end but the TL and mag pump add a lot... The whole time ive gust been wondering if the motor was really worth it when I still need TL and mag pump. With the money I spent on the motor I could have had both!
