- South Denmark
Hi Guys
After my winther rebuild of the engine and first start up im having a littel trouble with the carbs.
The problem is that the gas i running out in the middle of the carb ( The ring in the middel ) in idle and its a lot of gas runing out there. What is causing this?
I have cleaned the carbs twice but same result so im out of ideas.
Im thinking of some sort of fuel pump og needle witch could be stock...
Thanks
Thanks
