- CT
ok so i was riding my ski today it was going pretty well. then it dies on me. and after that it would always start up right away with a quick pump of the primer but if i gased it, it would fall on its face and die. i couldnt get it to go more then half throtle. my one way check valve is working but i noticed when i pull that there isnt any pressure in the tank. no air shoots out like it should. where else can i be losing pressure, if this is the problem. when i blow air into the valve it holds it. but when i ride then pull it theres no pressure
