New 2007 SX-R
Right now the boat is completely stripped minus the electronics.
-Getting the footwells reinforced with enclosures (Revs)
-Took off the stock graphics, and getting everything re-sanded and painting the entire up deck a glossy red, keeping the bottom black
-Skattrak drop kit, with a 80mm Nozzle
-TBM Baffled Waterbox with the rear exhaust
-RRP Pole with Carbon Fiber Turfed chinpad
-UMI 0 Degree Bars, with turn plate (installing xmetal)
-XMetal Throttle
-Wet Pipe With mod chamber
-ODI Ruffian Grips
-Blowsion Black Outlets
-Dual Cooling
-MSD Quick Connect
-R&D -1" Turn Plate
-UMI Trim Lever
Cutting out all the extra glue/sanding the inside down
-Jenetics Recharging flywheel
-Purchasing Advent 3 with remote switch(pending mx595 sells it to me)
-R&D Head with 27cc permanet domes
-Zforce freestyle porting, along with a 42mm true bore on my stock carbs
-Sato Speed Pump Cone kit 2 Cones
-Blowsion Rail Caps- Being Fiber glassed in, with a permanent fit
-Repitched and setback stock prop
-TBM Ride Plate, and Intake Grate
-Blowsion Dual Fuel Pick Ups
-Dual 500 Bilges with remote switches
-Returfing the rails (Anyone know where i can buy a kit?)
-Want a lightweight hood prefer carbom (if anyone has one for sale for a decent price)
Might be buying an xmetal pole kit also- see which one i like more
Should i paint the nose piece black to match either pole? Or a red to match the rest? What about the rail caps?
Pictures with ski tripped--
The ski is being reinforced/sanded/painted as we speak
This is my first build, still in the learning process about everything
Cyclinder/Carbs, and manifolds are being sent out tomorrow
-XMetal Throttle
-ODI Ruffian Grips
-Dual Cooling
-MSD Quick Connect
-R&D -1" Turn Plate
-UMI Trim Lever
