I just left the local boating supplies place and while browsing the painting supplies I saw something called Easypoxy colored top coat. It's a polyurethane. It must work just not sure how well without doing an epoxy primer first. I have tried Rustoleum paints, Tremclad held up the best, Duplicolor. Tried Minwax helmsman spar urethane, Por30 marine clear coat, all of them left the hull in less than 5 minutes of being submerged. The only clear coat yet that lasted the longest was made by VHT brake caliper clear but it took to the orange peel effect in a bit of a bad way.
