Super Jet Get JSS coil Rebuild or New Coil?
JetManiac
Stoked
Vendor Account
orlando
or you can go to NAPA and buy the 7mm or 8mm Beldin plug wire just like what JSS uses and do the work yourself. It takes about 30 minutes to do it yourself.
Yes, you can buy spark plug wire, MSD boots and terminals, epoxy/glue, solder, heat shrink, etc. and do the work yourself. However, if you have any question about your skills and knowledge to do the work, then why?
The connections are critical to be perfect and sealed for saltwater riders especially the plug wire to spark plug terminal connection.
The coils dont go bad. Well they can but its very rare.
JSS is the way to go. He has done tons of them for us and we have never had a problem. The upgraded wire and end sparks so much harder.
We have sold over 170 JSS coils to Xers with almost zero defects or issues over several years. Any problems are usually later found to be other electrical components.
JSS always stands behind their work.
Mark44
Katie's Boss
100% one place
g
JSS for me also, if you do it yourself you need to make an extractor tool to dig the wire out without harming the pins in the coil.
Tuscaloosa, AL
I agree with you there. But there are some people that can and some people that cannot and should not. Those need to call You!!!!!!!!
Honestly, I would probably call you and order one instead of doing one again just because I dont want to work on them any more!!!!!!!!!!!!! LOL
