kawishaul
I bleed GREEN!
- lake City, FL
This won't make a difference for starting. The 7 plug has a longer insulator length which causes it to run hotter during combustion.
Both plugs fire at the same time on the X2. It doesn't matter if you mix them up.
Check to see if your flywheel has spun. This will keep it from starting.
:261:Both plugs cannot fire at the same time. The engine wouldn't run because the time at each cylinder is at TDC (top dead center) is different. Also about the plug wire length the ignition on my x-2 is stock and the previous owner (my Dad) did not cut the wires either. You can fallow the wires back to the coil and feel which one goes on the back cylinder. The correct wire will be on the left if I remember correctly. I would check but sadly my skis and I are currently separated by 200 miles of road.
Before you try anything else please try this Josh with a new or charge battery that will start another ski.
