@OCD Solutions when you did this test did you have the third lump ground off of the flywheel? were you able to confirm that worked and gave the same timing on both cylinders?
The third lump was ground off but I can't attest to checking any of the other points.
I do remember moving my timing lead from plug to plug a few times and I don't recall any differences or changes. It's more of a spot check.
All my testing was done prior to them making the Zeal function with the lump still on there.
