aqua
the taco
- Jefferson City, MO
If you don't want to rely on waterdawg you might be able to modify the pipe malone is using for his skis (if you can get one). You can run an xft or 550 gas tank. I did not because the motor drinks fuel and you burn it quickly. All of my setup will fit in a sj (I have a sj bottom on mine) you need to relocate the front mounts and move your battery. Riva used to make upright intake manifolds, I havent' been able to find one yet but someone must have one. I have stock cylinders and yes the port timing is different than what you want, but it's still way more power than you've been dreaming about. However the cylinder can be modified by resleeving and while you are resleeving you might as well bore it for bigger pistons. I have a new pair of cylinders, pistons, head setup coming this week that put down some impressive numbers on Lamey's dyno. Bigger numbers than the 10mm stroker built for lenzi. (hp and torque). After I tune this setup, I'll be working on propping the 144mag pump. You can go as big a 1200cc on this platform, you cannot on the polaris or 62t platform. I'm done with the 62t motor, it's just not the same anymore.
The man has spoken. :arms: Hmmmm......Im only about 3hrs from you. Maybe I will have to drag my butt down there sometime and take a looky!!
