harry might have read this, he called me and is going to send me another head! nice!!!!don't bother, I ride at 8000 feet so spent big $ with harry to try and get it to run like sealevel,was a tuninig problem at first but ok now,but only a afew feet quicker,but no faster than my 2 other stockers,probably because of impeller, so verry dissatisfied, he did lighten flywheel,true or taper bore carbs,stock pipe mods,porting,big bore to 849,I made it very clear that he needs to weld fill the doems and then recut for an extra 50psi but it is only 150psi,now I have a wet and dry pipe to try, I guess the tuning nightmare is about to start again.
My buddy just had a stock superjet head milled down to increase compression by GroupK. He installed it last night and it is only reading 155psi?? WTF?? We are going to check with a snapon gauge after riding it a bit.
got new head from harry,200psi at 5200ft,175psi at 8000ft.rick at peakpower sports in denver set me up with 80 pilots and 152.5 mains,1.5 needle@seat,short silver spring to match wet pipe and repitched solas dynafly for high altitude,i will radar next week and post.harry might have read this, he called me and is going to send me another head! nice!!!!
got my goal of sea level speed 49 on radar,but off idle bog and surging throtle responce still sucks bad! who can help?got new head from harry,200psi at 5200ft,175psi at 8000ft.rick at peakpower sports in denver set me up with 80 pilots and 152.5 mains,1.5 needle@seat,short silver spring to match wet pipe and repitched solas dynafly for high altitude,i will radar next week and post.
Don actually types words, I just thought it was random letters in no order. I have never looked at what he types.
Just install a dry pipe on a stock engine.
I know 5 people who have had them...4 have cracked and/or blown couplers every other week.
The wetpipe is the way to go for reliability and low end.
For freestyle, I recommend flywheel, compression and head. Next, you HAVE to drop weight on the SXR. That made my 800cc Kawi hit like a mofo.
I rode a GroupK big bore and it was all top end. (Harry is more of a race guy. I wouldn't bother with porting or big bore (your allready at 800!!! until you have a wet pipe and flywheel)
