How do i do that ?Put the rear carb on the front and vice versa.
If you rebuilt the engine, and didn't change anything with the carbs you probably have an air leak on the lean cylinder. Spending your time trying to tune your carbs to take care of it is likely to end in another rebuild. Verify that your carbs have matching jets and screw settings and the internal filters are clean, if so, your problem is likely elsewhere.
