- B.A. Argentina
Good Morning!
Do you have the new Blowsion handpole with Ovp?
Do you have xscream Kawi handlepoles?
Hey, Chris do you have the Xmetal steering stop in stock
I would like to purchase this in blue. Unless you can recommend something with extra leverage for a 1200 triple.Thrust finger throttle lever 89.95
Hello!!
Want to buy
Cold Fusion universal pro series 7/8 "std bars turnplate 99.95
SuperJet 08-up pole side steering cable mount kit 39.90
Delivery is possible in Russia Moscow?
Fatty@JetManiac does the RRP OVP system take fat or regular bars?
ODI Lock-On Grips
ODI grips feature ODI patented Lock-On technology which provides easy installation and 100% slip-free performance. Include Snap Cap End Plugs.
ODI Rogue Lock-On Grips $33./pr sale 29.80/pr
Rogues are perfect for those who prefer a larger grip. Large raised pads and knurled surface texture offer improved traction and deep grooves which channel water away from your hands. Black or lime green.
ODI Ruffian MX Grips $33./pr sale 29.80/pair
MX grips offer the narrow diamondized pattern that made ODI Ruffian grips a classic, with an added half-waffle pattern for additional traction.
ODI Ruffian Grips $33./pr sale 29.80/pair (black, blue, green)
ODI Troy Lee Grips -black, white, red, orange, yellow, pink, teal $33./pr sale 29.80/pr
ODI X-treme Grips $33./pr sale 29.80/pr (black or charcoal grey)
ODI VANS grips (black, red, or natural gum) $33./pr sale 29.80/pr
Featuring the classic Vans ® waffle sole pattern and constructed from ODI's proprietary grip compounds for a consistent feel that provides exceptional control in all conditions.
Handlepoles and Parts
Pole Bolts
Handlepole pivot bolts
Pole pivot bolts fit all RN Superjets 1996-2020, FX-1 1994-1995, and are used for most a/m standup poles and hull builds.
RN 96-20 Yamaha OEM Super Jet stainless handlepole bolt $92.99 sale 81.89
RN 96-20 Yamaha a/m Super Jet stainless handlepole bolt $59.95
RRP new lightweight pole bolt $54.95
(Includes nut and 2 washers) weight 4.2oz.
SS jam nut and washer for pole bolt 3.95
Pinch Bolts
XMetal / XScream stainless pinch pole bolts 65.89/pair
Thrust stainless pinch bolts 65.95/pr
(46mm length under head to end, OEM threads size)
Thrust longer stainless pinch bolts 65.95/pr
(RRP and other thick billet brackets)
RRP pole steering cable holder kit 36.90
Pole Springs
Blowsion RN SuperJet stiffer HD pole spring 49.95
- fits all RN Superjets 1996-2020 and FX-1
OEM RN SJ pole spring new $74.99 sale 64.79
fits all RN SuperJets 1996-2020 and FX-1
RRP spring tensioner 24.95
Blowsion SN superjet stiffer pole spring 49.89
- fits all SN Superjets 1990-1995
2021+ SuperJet HD pole spring -Riva Racing $54.95
Kawasaki
Blowsion Kawi 750/800 pole spring 49.89
Blowsion Kawi 650 HD pole spring 64.95
Blowsion Kawi JS400/440/550 HD pole spring 39.95
Lighten that pole and lower upper body fatigue. Fits all years Kawasaki JS Model 300, 440 and 550/550sx. NOTE: Does not fit 300sx model.
Handle Pole Pivot Bushings
RN or SN Superjet OEM Yamaha pole bushings $10.99
(fits all SuperJets 1990-2020 and 94-95 FX-1)
RRP cast pole bushings 25.95/set
RRP billet and lightweight pole bushings 25.95/set
XS adjustable pole bushings 25.90/set
AC Racing pole bushings 29.95/set
Kawasaki 750SX/SXI/800SXR OEM pole bushings 9.49/ea
Kawasaki 440/550/550SX/650SX pole bushings-a/m 24.90
Oversized handlepole bushings for the Kawasaki 440/550//550SX/650SX.
(Your pole must drilled out the hole for these bushings to fit. These bushings are 7/8" diameter where they press into the handlepole.
Made from acetal/delrin.)
RRP Pole Bolt Spacer for CAST pole 35.95
RRP Pole Bolt Spacer for BILLET pole 35.95
RRP Steering stop/Chinpad Support 65.80
Thrust billet Steering stop/Chinpad Support 54.95
OEM SS Steering cable pole mount(U shaped) 9.95
Pole bump pads for hood
HydroTurf Pole Bump 1" pad 13.
(Has peel and stick for easy installation)
HydroTurf Pole Bump 2" pad
HydroTurf Pole Bump 4" pad
Pole Limiting Rope Kit
Limiting rope kit $40.90
includes:
-Stainless tray loop mount
-Stainless allen hardware with washers and nylock nuts
-Stainless carabiners -high quality 2x
-Stainless pole mounts -2 styles
-Sta-Set rope kit with elastic keeper and clip to pole base area
(High strength Sta-Set marine rope)
Handlepoles
XMetal XScream Billet Adjustable Handlepole kit
Complete kit includes:
Handlepole
Stainless steel pole mounting bracket
Aluminum hull backing plate
Dual pinch stainless pole bolts
Chinpad
Chinpad support/steering stop
Breather Hoses
*Standard pole comes with -2 to -5" adjustability
*Precision All Billet 6061 Aluminum construction
*Black powder coated finish
*3 bolt slide system keeps adjustments simple with no disassembly required
*XS pole is drilled and threaded to accept UMI, RRP, and other steering systems
*Pole weight only 10 lbs.
XMetal Billet Adjustable Standard length Handlepole kit (Yamaha) 775.
XMetal Billet Adjustable Competition length Handlepole kit (Yamaha) 775.
(Also available without pole bracket for 675.)
XMetal Billet Adjustable Competition length Handlepole kit (Kawi) 640.
Xmetal XS stainless pole bracket 135.
(includes aluminum backing plate)
Xmetal XS pinch bolts/nuts 65./set
Xmetal XS pole breather tubes 2x 14./ea
RRP poles
RRP cast adjustable handlepole kit $799.
RRP billet adjustable handlepole kit $1,125.
RRP billet LITE adjustable handlepole kit $1,199.
RRP CBX adjustable handlepole kit $1,425.
RRP Ninja Chinpad 320.
RRP handlepole replacement aluminum tube 49.95
Pole Brackets
RRP billet handlepole bracket for SuperJet and similiar hulls 319.
(includes RRP breather tubes, billet hull side hood hooks, and hardware)
RRP Rickter billet handlepole bracket 319.
*for RRP and similiar style hulls like Tigercraft and WCF Vision where pole bracket fits in pocket on hull, and hood hooks are not on pole bracket.
(includes RRP breather tubes and hardware)
RRP replacement pole breather tube 39.95
Blowsion lowered single hole pole bracket 279.80
(includes breather tube and stainless hardware)
HSI SN conversion bracket kit
PM sent.New to the site, but I was wanting to look into ordering a couple things. Can you PM me since I can't? Thanks.
