Handpole L Bracket
Ontario
Anyone know where I can get this L Bracket
I need 2 of them and cant seem to find any retailers that sell them. Off a SN, they are the bracket that attach the chin pad to the handpole. I recently removed my chin pad to replace my SS switch. But the bolts were seized, previous owner clearly did not use stainless bolts, and so I had to drill out the bolt from the brackets. I reallyyyyyy do not want to have to rethread the brackets. also if anyone else has encountered this issue before, do you have any ideas on using something else.
Zip ties. I have an aftermarket pole so my situation is not the same, but my chin pad has been attached with zip ties for a couple years now with no problem. I know it sounds hokey/cheap/whatever... but seems to work.
Ontario
so did you just ziptie the pad through the hole on the L bracket?
