Other Harbor Freight Compression Tester ( Crap ) ?
spookyjjj
Back @ it
Billings Mt
Has anyone else had problems with these Harbor Freight Compression Testers. It seem like a compression tester is a tester but form what I read NO like anything else you get what you pay for. But whats the best bang for the buck on something you only use a dozen or so times a season, I'm not a mechanic and don't need a snap-on or something with that price tag.... Thoughts please
naticen
wilmington, nc
I bought one at auto zone for $45. Lost it for a while and bought another to replace it. Now I found my old one and they read identical and where they should be. The first one is about 5 years old or so and we'll used.
spookyjjj
Back @ it
Billings Mt
Yeah I just put on a New ADA with 35cc domes and my Harbor Freight only read 140 in each jug I'm at 3200 elevation in the mountains, I think I'll try a autozone to see if that changes. Made for a tossing and turning sleepless night wondering wtf lol
High Speed Industries
Your one stop shop for quality parts @highspeedind
I had pretty good luck with my HF gauge until it died on Tuesday. It was pretty accurate, at least I think it was. I used it for 2 years and it because of something I did. I was buying a ski on Tuesday and I usually crank the motor over with the plugs out before I put my tester on it. That way I can see if there is any oil or water in the motor. I skipped that step and the oil in the motor killed my gauge. I believe the HF has a lifetime warranty so I'll go back and get a new one, but who knows how long the new one will last. I just need to make sure I get a Tuesday ,Wednesday, or Thursday gauge. Stuff that's made on Mondays and Fridays always breaks. lol
hhh
I HAVE USED THIS ONE FOR ABOUT 5 YEARS. I THINK IT WAS AROUND 50 NEW FROM A PARTS STORE. YOU CAN ALSO CHECK A TESTER WITH COMPRESSED AIR SOME CAN EVEN BE CALIBRATED IF FOUND OFF.
tomski
X
LHC
You need smaller domes for that elevation. The seller or dealer for your new head should have discussed that with you.
I have a compression tester that I purchased from Sears 15 years ago. It matches every high dollar gauge I have tested it against.
tor*p*do
Squarenose FTW
NW NC
My HF compression tester is GTG.
I brought it to work and had the cal-lab check it and it was spot on
MattyIce26
Matt S.
Lockport, IL.
I love Harbor Freight, but I tend to stay away from anything really valuable, (drills, saws, anything with power really) I was thinking about picking up one of these but now I'm not so sure
CRJ
Hibernating
Toronto
simple rule. if it says harbor freight, or its from china, its :):):):).
its black and white, with no grey area. yes... there are the few exceptions that will last for a little while.
spend the money, but tools that last.
