hello everyone
this motor is belong to a fraind of mine
61x cylinder
84mm la 5187b bb sleaves (installed witout any port timing at mind ),as is, and decked
wiseco dome top pistons
blowsion head
62t cases
engine is 2009
compression 190 psi ,gas pump
static timing at oem mark (no advance)
msd enhancer
hooker 9/15
v force 3 reeds
novi 3 single carb
now
the engine is runing rough at high rpm,somtimes the engine dies, while throtle released ,and will start up again
the engine done 20 fuel tanks
on friday after 2 tanks i dicovered the rear cylinder o ring leaking compression,next to the cylinder center(the pisser was spitting water)
bottom and is fair no dead spots but weak
i need some tuning advice
the piston wash looked rich to me ?
my feeling is the ignition timing is retarted way to much, but there isn't any overheating signs(like piston edge,or i am wrong, what do you guys think?
61x cylinder
blowsion head
62t cases
engine is 2009
msd enhancer
hooker 9/15
v force 3 reeds
novi 3 single carb
now
