- michigan
Adding some heal blocks to my dvx after I did the turf and found out my setup wasn’t good enough. I was wondering what people used successfully to keep these things on? Contact cement good enough? Should probably cut the turf/pad out to glue to the deck of the ski. I was thinking about using urethane adhesive not sure if it’s necessary. Thanks
