Weeds are a fact of life back in these creeks. For the most part you stay clear, but if you screw up your definitely stuck with a wad of weeds in your pump. If it's not too bad you can clear them by bunny hopping (they fall out) and if that doesn't work you can get going as fast your clogged pump will allow and then hit the kill switch. This will usually back flush the pump and clear it. If that doesn't work then your stuck with clearing by hand.
The best part of these rides is when someone eats it in a turn and ends up 20 feet up on the sedge bank with mud war paint on their face!
