Help. Advent curve
Hey just got a t3 advent ignition. Anyone know what switches to have set where.
08 sxr 800
Wet pipe
185psi
Reeds
Stock carbs
Stock motor
Msd coils
Stock prop
Thank you
PNW
My SXR setup was almost identical. I ran the T3 with the D23 Curve set. I think I ran SXI-22 curve and it ripped!
OCD Solutions
Rentz, GA
Just read everything but what is the last switch bar for and why are there 7 switches ?
Switch A has 7 dipswitches. 1-5 are used to set the RPM limit, 6 and 7 are used to select one of the 4 pre-programmed curves.
Switch B has 6 dipswitches. 1-4 are used to set up the water injection channel 1 switch point. 5&6 set Ch2 switchpoint.
Switch C has 6 dipswitches and is used to set the RPM trigger range for the water injection.
