spork
down with the sickness
- Indianapolis Indiana
I'm sure this has happened to someone else, but i ripped one side of the inserts out of the hull of my 95 750sx where the ride plate bolts to. Any idea the best route to take to repair?
happend to me, what pain in the ass!
Are you still selling these John?i have insert kits here, ( four inserts, bolts, and a little epoxy) for 15.00 + s&h. these are the correct size & thread.
let me know if i can help.
zig
They are on his website www.watcon.com. Now $25. I'm 99% sure this is a generic repair kit that you can use on pretty much any 'ski. As it's that 1% that will bite you I'd suggest you double-check with John before you buy.Are you still selling these John?
Sent from my SAMSUNG-SM-J320A using Tapatalk
No prob, I've never used these before, will the bolt install flush with rideplate?Thanks for the inquire.....
Yes, I have insert kits here still. Although the price has gone up in the last 10 years. (Sorry)
https://www.watcon.com/body-hull/hull-inserts/hull-inserts-1
Cool, thanksThey are on his website www.watcon.com. Now $25. I'm 99% sure this is a generic repair kit that you can use on pretty much any 'ski. As it's that 1% that will bite you I'd suggest you double-check with John before you buy.
Ok i see, thanksBe sure to mount insert flush with hull. You will re-use your stock plate mount hardware (bolts). The one that comes with the kit is used as a tool for installing them.
