Help!!!! cooling lines
Hey guys I need help, I am putting my ski back together, and I have a factory type 4 pipe, with a riva man..., I have dual cooling if anyone can help me out with a diagram it would be awesome or just explain how the f*$k this works it would be great.....Thanks guys
This is how it was described to me. I run a speedwerx pipe but should still be about the same I would think, someone correct me if I'm wrong. Run both cooling lines to the manifold, one on top and one on bottom. Then run one from the head to the back of the pipe. The other side of the head goes over the side. The second fitting on the pipe, from front to back, goes to the last fitting (stinger). The third fitting on the pipe goes over the side as well. Hope this helps.
