HELP !!! DASA 900
Montreal
HEY guys i just did a compression test on my 900 dasa on the work bench and the meter says 185 psi in the front and 30 psi in the back ??? wtf but the pressior is holding what am i doing wrong ???
thanks
Byeai
"Cheetos-Man"
Melbourne FL
Spark plug in the opposite hole and pressure tester in the 30 psi hole u pulled the throttle wide open and cranking it over for a few seconds
Sent from my SAMSUNG-SGH-I337 using Tapatalk
550/440
Maybe I'll get it all the way around NEXT time....
Arizona!
Rings may be done, might need a bore, might be a dry cylinder, splash some fuel mix in the holes, turn it over with plugs in both holes, then re-try the compression test. If still low, it's time to tear it apart and start measuring ring gap, cylinders and pistons.
That sucks bigtime, just saw the pics in the foresale thread of the carnage. Just goes to show everyone to inspect all used purchases before running. especially when lots of money is on the line.
Good luck.
